4l60e flaring after new tune video inside
Old 08-17-2011, 12:39 PM
BennyB's Avatar
Default 4l60e flaring after new tune video inside
so here is the video car flares but doesnt hit the limiter. the car never had a problem until after i got tuned for the cam. let me know what you guys think. Performabuilt lvl2 trans by the way
Old 08-18-2011, 01:12 AM
BennyB's Avatar
nobody?
Old 08-18-2011, 10:15 AM
LS1Tech Sponsor
performabuilt's Avatar
There are many things relative to the tune that could affect this, Maf and TPS calibration come to mind but being nothing was changed but the tune thats where I would be looking. However beware letting it do this repeatedly can result in a 3-4 clutch failure.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-18-2011, 10:31 AM
BennyB's Avatar
going back down saturday to try and get it figured out
Old 08-18-2011, 11:10 AM
Moderator
jimmyblue's Avatar
Can't watch these videos at work, How about you try
and describe the circumstances?
If your tuner likes to mess with trans settings, there
are things in a stock tune file that will let you hurt
yourself. Especially raising the max line % limit without
changing the force motor table where the 100% column
blows off all line pressure and the only thing keeping
you from stepping in it, is that limit value.
But being a smart guy and "leaning it out for power"
by faking the air mass readings lower, also steals from
applied line pressure < torque calc < air mass. Port the
MAF, ditto.
Plenty of ways to kill a 4L60E and lying to it tops the
list.
Old 08-18-2011, 04:38 PM
joecar's Avatar
If your MAF and VE tables are too low then the PCM computes the wrong line pressure, if it is low the clutches will slip.
Old 08-18-2011, 11:46 PM
BennyB's Avatar
im going to mention the maf and ve tables for sure. thats what im getting from a lot of people
Old 08-19-2011, 10:52 AM
LS1Tech Sponsor
MAF, ditto.
list.
Basically hes getting a lower presure apply and ending up with a rev/slid bump into 3rd is the best description I can give.
__________________
Call 888-744-6542
Old 08-21-2011, 02:09 PM
BennyB's Avatar
well i went down to let the tuner look at the car and try to figure out the trans issue, but he only made it worse. he came up with multiple reasons why it could be doing what it was doing. every ten minutes was something new saying it was a faulty converter to a slipping trans to a misfire.... he went on and on in turn pissing me off. i just told him put what we originally had for a tune back on and ill just take it back to the garage. im going to a better known and well respected tuner this friday.
Old 08-21-2011, 02:11 PM
BennyB's Avatar
i mentioned what was said on here about the issue could be caused by the maf and ve table settings and he acted like that would have nothing to do with why the trans was flare shifting. he just really pissed me off and needless to say that i will never see or talk to him again
Old 08-22-2011, 10:51 AM
Moderator
jimmyblue's Avatar
It's too bad there is no accreditation process for
"tuners".
"If you believe in things
that you don't understand
then you suffer..."
"Superstition", Stevie Wonder
Old 08-22-2011, 11:27 AM
BennyB's Avatar
"tuners".
then you suffer..."
yeah i agree lol
Old 08-22-2011, 07:34 PM
LS1Tech Sponsor
Slowhawk's Avatar
Looks like a line pressure/timing problem. As said above.
It's close but not close enough.
Old 08-22-2011, 07:42 PM
Gilbert@Ace Racing's Avatar
Guys this is a perfect example of why I DO NOT build a performance 60E with an EPC Solenoid. ALL of my units get a vacuum modulator. I've lost too dang many units to Tuners... units that were still in my warranty period no less! Since I started doing that I have not lost a 60E to soft parts failure.
It really is an unfortunate situation when a client spends a big chunk of his hard earned money and winds up caught between the tranny builder and a tuner who disagree with the cause of the failure.
Keep us in the loop on this...
g
Old 08-23-2011, 01:02 AM
BennyB's Avatar
g
will do
Old 08-24-2011, 03:20 AM
gregrob's Avatar
I would stab that tuner in the nuts. Likely all he has to do is increase the force motor current positive table to match the other changes he made in the tune.
Of course if he cant figure this out, the rest of the tune is probably "hacked" as well.
As was mentioned, if he didn't calibrate the VE and MAF tables properly to dial the tune in, it could throw the line pressure way off.
I'm not really saying anything these guys here haven't told you, just reiterating.
Find a new tuner
Old 08-24-2011, 04:07 PM
joecar's Avatar
The table has an inverse relationship, so you meant "decrease the force motor current table".
Old 08-24-2011, 09:43 PM
Moderator
jimmyblue's Avatar
Decreasing force motor current raises delivered pressure.
Old 08-24-2011, 10:15 PM
gregrob's Avatar
I know that, sorry I should have been more clear. But yes, decreasing the current will increase pressure..
Old 08-25-2011, 01:24 AM
BennyB's Avatar
Find a new tuner
the funny thing is the only reason i went to the tuner i did is bc my tuner was swamped and could only get me in at times that didnt work to well for me plus i was busy, but now with some time off i will be making a visit this friday
Quick Reply: 4l60e flaring after new tune video inside
