What bullet muffler does Texas Speed use in their true dual exhaust?
I ordered and received my Texas Speed true dual exhaust system, with the bullet mufflers. Just wondering what brand Texas Speed uses? Looking through the mufflers, there are raised triangle looking things all the way through the bullet and they kind of spiral down. I just want to make sure I did get the bullet style mufflers and not the spiral flow mufflers. If anyone can comment on what their Texas Speed true dual bullet mufflers looked like, I'd really appreciate it. Pics would be even better if you have any.
LS1Tech Premium Sponsor
The bullet mufflers we use now do have little raised things inside. They do resemble the Sweet Thunders. The main visible difference is the outside of the bullets is smooth, whereas the Sweet Thunders have a few little indentations on the muffler (almost looks like big machinery grabbed them and crimped them a good bit i those spots.)
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The main identifier of the Spiral Flows is that they are black on the outside
__________________
TSP's true dual with bullets are 18 inch Dynomax bullets, smooth on the outside, straight throught on inside but the inside wall is raised all along with the little pyramid looking louvers. I run bullets and from what I understand they are the best offering on the TSP system as far as flow rate and power goes, but the Sweet thunders are the better sounding ones yet lack flow. Small differences though if you were to dyno the two, maybe 5 hp. Never heard Thunders in person only over the computer, but I can tell you the Bullets definitely sound amazing, very deep.
The following users liked this post:
fucter (09-17-2021)
Matt at Texas Speed told me they no longer use Dynomax Bullets in their true duals. They use a different bullet muffler. I just received mine last Friday, which is why I was asking the question I did on the original post. Got everything figured out now and I did get the bullet mufflers, but like I said, they aren't Dynomax because that's not the bullets Texas Speed uses anymore. Regardless, I'm sure they will sound and perform badass.
Ahhhh I stand corrected, I got mine about a year and half ago when they were still Dynomax. I was unaware they swtiched. (run away with tail in between legs....)
I bought Dynomax bullets about 3 years ago and they were perforated. Buddy bought some Summit bullets and they were louvered inside but looked almost identical on the outside.
