What can I use to clean the block threads out?
So since everyone including ARP told me to re do the heads with lube AND sealant then I'll do this tomorrow. I was also advised to clean the block threads out. Ok fine, but with what? The block is pretty fresh with only ARP ultra-torque lube so it shouldn't be too bad but I'll need something to get down in the holes with.
Also, since the head gaskets are only bolted down and never used, do I still have to replace them? Thanx
Yes if you separate the pressure entirely from the head gasket.. their cashed .they start out at one thickness and crush to another during tightening to seal, if you going to remove the entirely use a tap to chase the threads, Or if you haven't put sealant on them just pull one at a time add sealant and retorque.
E
E
Also even though your block might have been cleaned by a machine shop, (hot tanked or pressure washed) the threads can still be dirty. Some of the books I have read recommend doing this prior to handing block over to machine shop to help minimize contamination of surfaces with grit near a fresh build.
You don't want to use a thread tap. The correct tool is a thread chaser.
Over time through tightening and loosening, threads can become slightly distorted in the block. If you use a tap, instead of reshaping the threads you end up cutting them and actually make the threads weaker. A chaser simply reshapes the existing metal instead of removing it. It also helps to remove the gunk left in the threads. Use a light oil when chasing also. Do your best to vacuum out any dislodged gunk too.
This might not be a bad idea, and would save you some work. If you did this you might want to drain coolant. I would just follow the torque pattern when pulling bolt by bolt.
Since this is on the stand, this will be much easier.
