DTC P0704 clutch switch circuit
Old 08-18-2011, 11:47 AM
SSoofast's Avatar
Default DTC P0704 clutch switch circuit
I just had a new clutch and Tick master cylinder installed and now i'm getting a ses for P0704 clutch switch circut.how do i fix this .The car only starts when the clutch pedal is depressed like it's supposed to do.is the switch on the pedal somehow out of adjustment.Can i set the dtc enabled for this dtc to not reported?
Old 08-18-2011, 01:23 PM
VIPRETR2's Avatar
https://ls1tech.com/forums/manual-tr...416-p0704.html
Post number 4 has your solution, pics in post # six.
Old 08-18-2011, 01:49 PM
SSoofast's Avatar
Thanks VIPRETR2 i think thats the fix since my pedal now sets lower also.I'll give it try.Good to see pics of what i'm looking for(switch).
Old 08-19-2011, 12:45 PM
LS1TECH Sponsor
Joey@Tick's Avatar
Bingo. In some cases, our kit requires re-adjust of the factory cruise control switch in order to make contact with your now-shorter pedal. Easy fix!
Quick Reply: DTC P0704 clutch switch circuit
