oil filter feed and return, from Oil Galleries
I'm currently swapping a lq4/4l80e in to a 92 gmc typhoon. I bought most my parts form sytyperformance. The oil pan does not have a have a spot for the oil filter to go. I should be able to block those to oil ports and run the oil filter feed and return threw the oil galleries side of the block correct? I should be running -10an line or can i get by with -8 an line for the remote oil filter housing.
