Exaust setup! Whatcha think?!?!?!
Old 08-19-2011, 06:08 AM
RebelMan666's Avatar
Question Exaust setup! Whatcha think?!?!?!
2000 Ws6 stock with a volant intake and a magnaflow catback. Comin up on 40,000miles. Lookin to beef up the exhaust a bit. Texas speed longtube headers, 2 cutouts after headers, Off road Y-pipe to the magnaflow and a tune... Parts and labor together comes out to $2,000.
Yes? No? Whats your thoughts...
Old 08-19-2011, 06:17 AM
What are your thoughts on the Volant Cold Air Intake as well?
Old 08-19-2011, 06:18 AM
hookngo's Avatar
That sounds good bt high on price labor in all 1500
Old 08-19-2011, 09:27 AM
udienow's Avatar
I think the dual cut-outs is overkill. Its debatable in the first place if the cutouts even add HP. I have a single cutout after merge and about all I use it for is to get my car louder, as the magnaflow cat-back is quiet. I would go with whatever headers, into a y-pipe, single cutout in the I pipe.
Also all this should not run you $2k. TSP headers $500, y-pipe $130-350 depending on cats or not, $150 tune (i assume basic not dyno), $200 for a e-cutout, and maybe what another $3-500 to install it all?
That $1500 figure posted above is more accurate for a fair price, unless ur doing a full dyno tune.
Also, dont forget plugs/wires and I would also consider doing motor mounts at this time while headers are out... but thats just IMO.
Old 08-19-2011, 09:55 AM
Formally Simplɘ Jack
BoricuaHec01's Avatar
All that should NOT cost you more then 1500 bux.
Old 08-19-2011, 10:57 AM
LeanPocket's Avatar
it costed me about that in parts and labor
that extra cash is prolly with a dyno tune im assuming? Def worth it in my opinion
OP might also want to invest in porting your induction items while your at it for a lil more dough
I would look into true duals if u want good flowing exhaust
duals > y
but dual cutouts is a good idea if u want to keep ur y setup, however i would get the turndown accessory .. not necessary but if i were you I would look into it
Old 08-19-2011, 04:16 PM
its with a dyno tune which is about $$5-600
Old 08-19-2011, 04:58 PM
I got a estimate from Speed, Inc for pacesetter LTs, tsp ory, wires, plugs, gaskets, dyno tune, install, tax for 1400, not bad.
Old 08-19-2011, 06:36 PM
LeanPocket's Avatar
Old 08-19-2011, 08:25 PM
. I still have to wait though
Old 08-20-2011, 12:55 AM
stlracing289's Avatar
I have a Volant Air intake as well! I have to say it makes your ss hood 100% functional for 98-02 camaros...When you race someone is sounds like something firece for sure hearing it sucking all the air in...
However I have no idea how they compare in performance with a SLP intake setup..this was on the car when I bought it and doesnt have the original tray so i cant change over to see the difference
Old 08-20-2011, 01:08 PM
NewLS1Owner's Avatar
The TSP headers come out to about $550 with O2 extensions. Skip the cutouts, or if you feel you really need it, just put one in after the merge. Personally, i'd just grab TSP's true dual setup. you can get that and the headers for about $1050.
Old 08-20-2011, 06:47 PM
with running the cutouts would i have to worry about burning up the valves?
Old 08-20-2011, 06:54 PM
LeanPocket's Avatar
no.....
but if anyone has had an issue with burning up their valves while running a cutout or ory/orx/orh correct me if i'm wrong
Old 08-24-2011, 11:41 AM
ToxicWS6's Avatar
sounds like a decent setup, i personally had 2, 3inch cutouts i put right after each header, theres a big diff between both them open there then 1 open after the Y merge, WAY louder and easier to get too if u dont have electric, performance wise i couldn't really tell as my exhaust was pretty much straight through anyway, but if ur doing to be able to run open headers for the sound id do 2 right after the each header
Old 08-24-2011, 11:51 AM
Thanks, hey btw your front license plate cover.. did you get that hand painted or what'd you do to get the bird red??
Old 08-24-2011, 10:17 PM
ToxicWS6's Avatar
i hand painted it, its not super great really close up but from 5ft away looks fine, just got some red paint in a shade i liked from a hobby store, the little glass bottles, and cleaned it real well, then was lazy cause i forgot a paint brush so i used a paper towel rolled up XD but it came out pretty good imo, then a cop told me to take it off so now its hanging on my wall : \ but thats fine, theres an intercooler there now lol
some one else mentioned to me after words if u get tape and tape off tthe whole thing then go over it with a exacto knife or razor blade and cut the bird part out then u can just spray paint it, might come out cleaner that way, just clear coat the whole thing after words and it gives it a better look
Old 08-24-2011, 10:24 PM
ToxicWS6's Avatar
heres a close up pic
Old 08-26-2011, 06:29 AM
That looks Sick! I took out the two plastic grills on the hood of mine and painted them red along with the two infront of the doors. Definitly wanna do that with mine along with the break calipers. did you do any sanding on yours or just paint it then clear coat?
Old 08-26-2011, 07:24 AM
garygnu's Avatar
if you are going to dyno it consider adding a ls6 intake and ported TB.you could get by with a mail order tune from frost.
