Livernois Motorsports Dual Valve Spring set sale! $50 off!
One thing many people overlook when changing to a more aggressive camshaft is a good valvetrain. Until August 31st, we will be running this sale on our dual valve spring kit, which includes springs capable of .690 lift! We have a customer with 120,000 miles on his head/cam Corvette. 90,000 of those miles are on a set of these springs with no problems!
Install Height: 1.820
Max. Valve Spring Lift: .690
Spring Pressure Closed: 150lbs
Spring Pressure Open: 382@.620 / 410@.680
Coil Bind: 1.100
Retainer Material: Titanium
Livernois Motorsports Dual Valve Springs (16)
Livernois Motorsports Titanium Retainers (16)
Livernois Motorsports ID Valve Spring Locators (16)
Super 7 Locks (32)
Rubber Valve Seals (16)
Note: Valves NOT included in kit
No cutting or machining of the stock spring pocket necessary.
$339.99. Normally $389.99.
Please order from the following link, they are listed at $354.99, but after you add them to your cart a discount will apply. Due to the current discounts we are running on all products, this is the way we had to price it.
http://www.livernoismotorsports.com/...pring-Kit.html
Thanks,
Chad @ Livernois Motorsports
Coil Bind: 1.100
Super 7 Locks (32)
Thanks,
