front mount pictures & video's
Location: Home town Clive,IA current town FORT BENNING GEORGIA
hey guys im currently switching over to the turbo world and would like to see some set up's and here some turbo'd cars. The reason i'd like to see these is just for motivational reasons. i currently just bought the spoolin performance set up and am now. So if you would please post some **** up id appreciate it
thanks for the pictures, now if only we could people to bring on the fly by videos. also which BOV are you guys running i would like something loud
yeah guys are really helping me out...
my set up should be as listed:
317's w/dual gold springs
ls6 cam
spoolin performance t4 flange truck manifold kit
GT-91mm 1.08ar
cxracing itercooler
twin walbro's (already have one from previous set up just need to get the second and the fitings)
ls6 intake
80lbs injectors
the only thing im not really sure on is which gear i will be running, or which BOV OR Waste gate ill be running
ls6 cam
GT-91mm 1.08ar
cxracing itercooler
ls6 intake
80lbs injectors
Setup: 128,000 mile stock bottom end with valve job / milled 243's (11:1 compression)
Made 444 rwhp 414 tq N/A
Bre 224 n/a cam (single pac 1518 beehives, valve float above 5800 rpm)
Ported fast 85
KYTP Truck manifold setup with Precision 76GTS on 8lbs of boost
Alky Control Meth injection with 100% meth and 92 pump gas
3700lb + raceweight
MWC Fab 9" with 3.50 Gears
T56 with Mcleod RXT Twin (amazing clutch)
26"x11.5-15 M&H Cheater slicks
Stock slp bilstein shocks with lowering springs
Stock Lower control arms
Bling Bling
Push to connect fittings
Ported fast 85
3700lb + raceweight
Bling Bling
Some pictures are with the 76mm. It now has a pt88 on a stock bottom end. Cam, pushrods, valve springs, and rod bolts on e85.
http://www.youtube.com/watch?v=L0SO_aFL2Ys
