Swivel Joint LCAs?
Swivel Joint LCAs?
(I tried searching for this but came up empty...)
Is anybody running these pieces by Founders Performance?
http://www.foundersperformance.com/p...mbination.html
It sounds like this would address a lot of the binding problems with Polyurethane bushings...
I am familiar with Roto-Joints, Rod Ends, Poly Bushings, etc, but this is the first I've seen this particular configuration.
This design has been around for a long long time. The original was the Johnny Joint by Currie Enterprises. Here is a link to watch the Currie video if you would like.
http://www.currieenterprises.com/ces...nnyjoints.aspx
Ours are exactly the same all the way down to the bushing manufacturer except for a spirol lock instead of a snap ring and we use thicker support washers.
I hope this helps,
Ryan
