Lost alternator on the freeway
Was entering the freeway and at about 5500RPM at WOT in 3rd gear, voltage drops from charging to non-charging.
Got to work and the belts are still on there. Is it possible I blew a fuse? Why would it go out at high RPM?
Thanks
Thanks
Mine did the same at even lower rpm's, I was cruising behind a slow *** minivan around 65, dropped it into 4th to get by it and almost 10 min later my lights are mysteriously out. Ends up two of the 4 diodes took a dump, replaced it with nice 220 amp piece so all is good now. Heads up IF you do end up having to get a new alternator, when you're taking the old one out you're better off taking the entire bracket out at once cause it's a complete PITA to seperate the alternator from the bracket with it still bolted to the block. Oh and by careful with the idler on the bracket, I was careless with mine and it's whining like crazy now :/ sounds like a procharger though so I guess it's not THAT bad muhaha
LOL tips on making my alternator sound like a procharger?
Im going to check for charge tonight if i make it home.
I heard removing the alt was easy, 3 15mm bolts and it comes out.
From my understanding:
1. disconnect batt
2. use wrench and push down on tensioner, remove belt
3. disconnect alternator
4. unbolt 3 15mm bolts on alternator - remove. transfer pulley to new alternator
does that sound right?
Mine used to drop voltage at high rpm as well. Turned out I had a bad excitor wire. They are available on ebay for pretty cheap and you splice it in. My problems were solved after I replaced mine. I guess the heat got to it or something.
It's the plug that goes into the voltage regulator on the alternator. The wire becomes brittle with heat or in my case, the wire pulled away from the pin in the plug. Either way, buy a new one and splice it in. It's cheap and will likely fix your problem.
1. disconnect batt
1. disconnect batt
well guys, got a reman alternator for 85$ with a lifetime warranty from a place called "rotex" in the LA area. they also do starters and generators. great place for anyone local. the new one came with a pulley, so no need to remove the old pulley. put it in and now it's running a good 1.5 volts higher. with the old alternator it was only running 13 volts at all times. install took about 15 minutes!
only thing that might hold someone up on this, is trying to remove the plug to the exciter wire. the quickest way seems to be, have a spotter with a flashlight up top looking down on the top of the alternator, and you underneath with a small flathead, while the spotter guides you~
