multiple fuel lines...WTF?!
i just had my car at the dealer and the service tech told me my camaro had 3 sets of fuel lines. i understand one is the feed and the other is the return but the third line seems to serve no purpose...it just goes up to the metering block. He said the lines were installed with factory style lines and the job was done very well. does anyone know what if any purpose this would serve? it almost seems like they wanted more fuel to go to the engine but that makes no sense. weird, huh?
That's MISTER MODERATOR
All LT1 V8 engines up from 1993 to 1997 have three fuel system lines, a feed, a return and a EVAP vapor return.
All V6 cars through 2001 also have the above three line setup.
Starting in 1998 through 2001, all LS1 V8 engines are a two line system, a feed and a EVAP vapor return.
Your sig and post don't tell us what engine you have. Is your engine a V6?
If your car is an ORIGINAL V8, you'll need to post up some pictures.
it's a '98 ss, original ls1. i find that strange. maybe i have an oddball?? i'll have to check it out myself and get some pics. at this point i'm willing to believe that a mistake was made. either way, i'll get some pics and hopefully some light can be shed on this issue. thanks for the input thus far, guys.
