Recommended Springs??
I have a 230/232 .595"/.585" cam and going with ported LS6 heads on my LS1. what kind of springs to I need to achieve the most out of the engine?
If you have the lightweight LS6 valves and want to preserve the advantage that they provide you will want a good beehive spring -e.g. PAC 1518
On the other hand, if you do not have the lightweight LS6 valves; or want the added insurance that a dual spring provides you will want a good dual.-e.g. Comp 921s.
You could probably "get away" with a beehive Comp 918 or PAC. A buddy of mine is doing that with a similar but slightly smaller cam.
But.... I would personally run a dual like patriot gold or PRC's. You could also get the higher dollar Comp 921 or 926 springs, but might be a lil overkill.
Go with the PRC .650 dual spring kit. The PRC kit has the best components money can buy, with no loss in quality. No need to waste the extra money on the comp stuff.
Restricted User
They proved that was a myth with back to back dynos with the pac singlse and the prc dual springs they dynoed and with the doubles they made more power. I think they said it was because the duals controlled the valves better at high rpm
