Need help with Lt1 tune and TC apply
Old 08-20-2011, 09:09 AM
rickou812's Avatar
Default Need help with Lt1 tune and TC apply
History: 1995 obd1 383 Lt1 tuned by mail PCMforless. Very happy with the tune over all, but have one issue I can not figure out.
The torque converter is locked on the 2-3 3-4 shift at part throttle and WOT. I can prevent it from locking by holding the brake during the shift.
I have emailed back and forth with Brian at PCMforless and says there is nothing in the tune that would cause this. I think it has to be tune and not mechanical due to the fact it will not lock if the brake is depressed.
Can anyone shed any light on this situation.
P.S. NOT the car in the sig..
Thanks,
Rick
Old 08-20-2011, 10:09 AM
1320's Avatar
Im not sure about this at all. I havnt been under the dash of an lt1 car in awhile. There might be 2 or 3 switches on the brake pedal though. One might be faulty....causing this. Seems like a possibilty, that the lock up solinoid is getting grounded un intentionally in wiring somewhere. You can probably prob the wires with just the key on, since it wont lock up in 1st, even if its energized. Double check that though, with someone else. I d call rossler or equivalent.
Old 08-20-2011, 01:33 PM
sreve's Avatar
first place i'd look see pic.
seems unlikely he missed it
brake switch keeps power to pcm and interupts it when brake pedal is depressed
Old 08-20-2011, 01:50 PM
rickou812's Avatar
Here is what I have:
I wonder if checking the "Upshift Turns TCC off" will fix it?
Attached Thumbnails Need help with Lt1 tune and TC apply-tunerscreenshot.jpg
Old 08-20-2011, 02:47 PM
2xLS1's Avatar
That is unchecked on stock calibrations so I doubt it. It is really unusual to have TCC lockup in second. What do the normal lock up tables look like. What you posted is the WOT lock up table. Or just attatch the whole bin.
Old 08-20-2011, 03:58 PM
rickou812's Avatar
Here is the whole tune file. Change the file extension to .bin or .lt1 to before opening. Had to change due to the forum upload.
File Type: tun
Old 08-20-2011, 04:04 PM
rickou812's Avatar
It is only locked on the 2-3 shift if I am over 40 mph part throttle or WOT shift which occurs around 83mph.
It is noticeable even with light throttle 3-4 shift which occurs around 50mph. When shifting into 4th it bogs the engine. This engine has a pretty large cam and a 3600 stall converter, so it quite obvious when it is locked..
Old 08-20-2011, 04:56 PM
2xLS1's Avatar
I keep getting an error saying I need Def $Ef to open the file. If I tell it to proceeed any way the data in the tables is whacked. I'm using TC v2.26 and $EE vCY. And yes I changed it to .bin. And I would think for it to be locked on the 2-3 shift it would have to be locked in 2nd before the shift is commanded.
Old 08-20-2011, 05:03 PM
rickou812's Avatar
Not sure why, but it does that on mine too if I change it back to a .bin file, but seems to work if changed to a .lt1 file.
Try the .lt1 extension. I think I may have "Saved as" .lt1 when I could not upload the .bin Then noticed that the forum wouldn't allow .lt1 upload either..lol
Also note, I already made changes to the "TCC WOT Force Lock" table but have not tried it on the car yet. The tune that is in the car reflects the screen pic I posted above.
Old 08-20-2011, 06:44 PM
sreve's Avatar
.lt1 seems to work.
I did not see anything in the tune that would cause it. Interesting though the B-body
cars seem to have the box checked and not the F-bodys hmmm...........
There are several differnt BBCs though, maybe that will fix it.
Old 07-22-2013, 12:02 PM
RamAirRocket's Avatar
Old thread I know, but good to document....
The .LT1 vs .BIN (tunercat) is simply the E Side first in the .LT1 and the T Side first in the .bin (tunercat).
So with some hex editing you can make a .LT1 a real .bin or a .bin a .LT1.
Quick Reply: Need help with Lt1 tune and TC apply
