which intake gasket for lq4 boost?
Old 08-20-2011, 09:46 PM
jks67ss396's Avatar
Default which intake gasket for lq4 boost?
Hey guys
Hows the felpro stock type gaskets work for boost on an lq4? The black plastic with the orange orings?
Do i need the metal permadry type intake gaskets or something else entirely?
looking at 15psi boost.
thanks guys!
Old 08-20-2011, 10:09 PM
HydroStream6's Avatar
Gm mls. Ls9 is all the rage right now. 7 layer.
Old 08-20-2011, 10:49 PM
jks67ss396's Avatar
sorry man.. looking for intake gaskets. not head gaskets. already got the heads on
just looking for thoughts on the intake gaskets... stock or something else?
thanks
Old 08-21-2011, 08:26 AM
jks67ss396's Avatar
bump up
Old 08-21-2011, 10:35 AM
stevieturbo's Avatar
If you're using a stock intake, with the stock o-rings, why would you even consider downgrading to anything else ?
Old 08-21-2011, 10:50 AM
jks67ss396's Avatar
downgrading? not quite sure i understand.
Ill be running around 10-15 lbs of boost with the stock lq4 plastic intake
heres my options:
1) use the stock type plastic gaskets with the orange orings
2) upgrade to the metal gaskets with orings (these are the permadry ones)
3) something else even better
so id like to know: for boost, is the stock plastic type fine or do i need to buy the metal perma-dry type or something else
thanks
Old 08-21-2011, 02:09 PM
Well, how can you upgrade from something that works perfectly and is effectively free ?
Old 08-21-2011, 02:27 PM
dschmittie1's Avatar
I am assuming since you said plastic with orange rubber you are using a truck intake. (which the gaskets are totally different than ls1/6 gaskets)
I would recomend getting some new GM gaskets they updated them the Orange ones have issues and the new ones are green rubber with plastic And they work really well.
Old 08-21-2011, 02:30 PM
Fair enough, I assumed the truck was same as LS1/6
Old 08-21-2011, 05:18 PM
jks67ss396's Avatar
so the plastic/green rubber ones work great for boost?
yep, truck manifold.. lq4
thanks
Old 08-21-2011, 10:44 PM
jks67ss396's Avatar
Can anyone confirm the green oring gaskets (89060413) will hold at 15 psi?
thanks guys
Old 08-21-2011, 10:54 PM
SirNemesis's Avatar
Yes, green ones here at 15psi+, no issues.
Old 08-21-2011, 10:56 PM
jks67ss396's Avatar
thanks man!!
Old 08-21-2015, 02:53 AM
Claydos's Avatar
hey man, looking for the same gaskets in Brisbane, just wondering where you got yours from? also how is your truck/car running? Any other tips? I am trying to run an ls with nnbs truck manifold in a patrol.
thanks
Old 08-21-2015, 08:43 AM
thanks
Just use the factory gaskets, they rarely need replaced.
Old 08-21-2015, 09:04 AM
Restricted User
JoeNova's Avatar
The number of people that far overcomplicate their setup is almost painful anymore.
Old 08-21-2015, 10:35 PM
Claydos's Avatar
Thanks for the straight up useless information team. Simply put the standard o-rings don't f*cking work on the truck manifold. If they did I wouldn't be f*cking asking the question. I brought a truck manifold and it came with the manifold and fuel rail, thats it. Hence the quite simple question asking where he got his gaskets from.
Here's an idea from now on if you don't have the answer don't post a reply
Old 08-22-2015, 01:39 PM
Or another idea...find out why the OEM gaskets dont work for you...but do work for everyone else ?
Old 08-24-2015, 04:16 PM
forcd ind's Avatar
Ask stock48 on here what he is using, he is making serious power with a truck intake
Old 08-27-2015, 04:48 PM
rryan5429's Avatar
Default intake gaskets
I run a stock truck intake with just factory gaskets. I'm on 17psi and 800 to the wheel. Don't have a ton of time on it yet. But it hasn't been an issue to this point.
Quick Reply: which intake gasket for lq4 boost?
