General LSX Automobile Discussion Non-technical LSX related topics.
A/F Ratio Gauge Install..
Old 08-21-2011, 12:24 PM
BrdOPry's Avatar
Default A/F Ratio Gauge Install..
Installing a Air to Fuel gauge, I know it's narrowband and won't show anything, but which wire do I connect to? I've read that it is the purple wire off of the O2 sensor, but I tried that and it just stayed all the way rich..Any help? 2001 Trans Am
Old 08-21-2011, 07:51 PM
bayer-z28's Avatar
Looks like purple is only the high feed to the PCM. Not sure if it will work that way. You may need a WB.
Old 08-22-2011, 03:58 PM
BrdOPry's Avatar
Thanks for the reply..I saw the same on the wiring layout..I tried to hook it up to the purple only and noticed it was stuck on rich, which explains a lot, I guess once I do a cam swap I'll invest in a W/B then. lol
Quick Reply: A/F Ratio Gauge Install..
