Casting Number on right side?
Old 08-21-2011, 03:57 PM
ekwoodard's Avatar
Default Casting Number on right side?
I have an LT1 engine, I removed from my aunts single owner wrecked 96 vette. It is the original engine for the car. It has a casting number of 101253227 located on the right side (passengers) on the flange behind the head. It has a 5.7 stamping on the left side. See my confusion any ideas?
Old 08-21-2011, 04:05 PM
96TransAmboosted's Avatar
What's confusing? 5.7 is the displacment. Should also have a 374 on both sides of the block. And more numbers in front of passanger side head.
Old 08-21-2011, 05:01 PM
IronOutlaw's Avatar
Every LT1 Ive seen have had 5.3 on the side but they have all been Fbody motors.
Old 08-21-2011, 05:16 PM
5.3 where do you get that from? why would they put 5.3 on a 350ci motor? that would be very confusing for someone trying to make sure the engine is original or where it came from. Every lt1 or almost every sbc i have ever seen has displacement on the driver side rear below the head surface area. it also has a little clock look symbol that says when it was made. I be leave below the freeze plug or in between them on both sides is a 327 casting(meaning lt1). Then in front f the passenger side head surface area is an engine code. This can be seen with heads on or off.
Old 08-21-2011, 05:19 PM
IronOutlaw's Avatar
Im retarded. I was thinking of 327 and thought 5.3.
Old 08-21-2011, 09:45 PM
FormulaJoe's Avatar
LOL right with ya there on that one.
Old 08-21-2011, 10:04 PM
Gojira94's Avatar
Block part # is 10125327, not 101253227. Last 3 digits are in raised numbers on the block. The casting marks above the bellhousing just aft of the driver's side head has the 5.7 you're describing.
374 is the last 3 digits of one of the factory cylinder head castings (10128374).
Old 08-22-2011, 12:17 AM
ekwoodard's Avatar
Default Sorry I Should have been more clear
What I find confusing is that the casting number is on the passengers side instead of the drivers side. I am not an expert by any means but I expected it to be on the drivers side. The shift clock and date code are on the drivers side. As anyone else ever encountered this?
Old 08-22-2011, 11:02 AM
Yes , the numbers are on the passanger side. thats how all my ltx motors are.
Old 08-22-2011, 12:24 PM
Purple Poncho's Avatar
Was the Vette a 6 speed?? IIRC 96 6 speeds had the LT4.
Old 08-22-2011, 10:07 PM
ekwoodard's Avatar
Maybe let me check that casting number again. Was the LT4 a 5.7 also? Sorry for the sarcasm maybe I should just say No it was not a six speed.
Old 08-22-2011, 10:10 PM
bigj2717's Avatar
Yes the LT4 was a 5.7. If it was an LT4 it would have a red intake manifold
Quick Reply: Casting Number on right side?
