does anybody has a s60 rear with a th400 combo and if so does the stock driveshaft fit and if not was ur measurements on the driveshaft
I have that set up but you need to measure for the drive shaft you need. My measurements may not work for you. Pinion angle, control arm length and so on. You want the yoke of the drive shaft to be between 3/4 and 1 inch from bottoming out. Also the rear joint for a S60 is larger than a stock drive shaft.
Go to the shop that is going to do the drive shaft and ask them how they want the shaft measured. Mine wanted it center to center of the U joints.
ok thanks im going to go ahead and order the rear and just wait until it gets here and do some measurements it was just trying to do this all end a wknd
