Cadillac CTS-V - Where do i get a cv joint?????
sciroccokid
08-22-2011, 05:13 PM
I toasted my drivers side axle and cv joint last night. I want to get the gforce anti-wheel hop kit, but it does not come with a CV Joint.
The only CV joints I can find are the ones that come with the axle. Does any one have any ideas?
Is there a place to get a stock cv joint?
Is there an affordable wheel-hop kit that comes with cv joints?
Really need to get this beast back on the road, but don't want stock axles!
Advice please!
Wooter
08-23-2011, 06:15 AM
I have a pair of axles out of an 04. Both are missing the outer stub axles. Which do you need?
Glenn
punishmentcycle
08-23-2011, 08:56 AM
i have a pass side axle with good CVs.. 60 shipped
BudRacing
08-23-2011, 09:18 AM
Why not call g-force? I'm sure they can fix you up with whatever you need in terms of axles since that's the route you want to go anyway.
sciroccokid
08-23-2011, 09:32 AM
Glenn
That should work. I just need the inner cv joint for the passenger side rear. I will be using it with gforce's anti-wheel hop kit. Send me a PM and I will buy it off you in a heartbeat!
sciroccokid
08-23-2011, 09:33 AM
Need the CV for the driver's side, unless they are the same that won't work. Thanks though.
sciroccokid
08-23-2011, 09:35 AM
I tried. They don't have cv joints, which seems weird. The anti-wheel hop kit comes with axles but no cv joint. That is unless you get the $1,800 1000hp kit...
GM sells the cv joints with the axles, and since I am using the antiwheel hop kit's axles this seems like a waste.
punishmentcycle
08-23-2011, 10:04 AM
the CVs are all the same.. if you want it its yours
sciroccokid
08-28-2011, 03:58 PM
I need a rear diff & will buy from the first person whose got a solid one to sell.
Thanks,
Wooter
08-29-2011, 05:33 AM
sciroccokid, shoot me an email, im not sure my PM's are making it thru....
gmr2598 at gmail.com
sciroccokid
08-29-2011, 10:17 AM
Thanks Wooter! I'll message you later.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
