Can i get 3.42's for my 98-02 a4
I know i put up some stupid threads up a little while back that i could have just searched. Sorry. But this question i searched and didnt find. I want 3.42 gears for my a4 with stock 2.73's. And i was shopping for them and a set said you need series 3 carrier and i wont work for series 2 carrier. Do i have series 3 or series 2. And what is this??
Easy on the newbie, we can move the thread.
OP, you need a 2 series 3.42. However, all stock 3.42s are 3 series. So, your solution is to buy a Motive thick gear 2 series 3.42. They make them because i installed one in a ten bolt just a couple months ago. Jaws gear likely sells one, and I know Summit/Jegs should too.
or you can do what i did.. i got a carrier with 3.42 gears online(ebay) it was 150 for the posi carrier and gears.. i wanted 3.73 but times are tight and 3.42 will work for now... and the posi and gears looked to be in great shape...
The posi is what is 2 series or 3 series. If you replaced it with one or the other then you could run the corresponding gear to match the posi. As far as installation I would buy a full rebuild kit if it was me. Fresh bearings help these over-powered rear ends last longer IMO.
Okay. When im turning in a curve around 25mph i hear a clunking/ clattering sound from the back end. If i get the gears installed will they replace some of that stuff and fix whatevers wrong
