Gen 5 Camaro Drivetrain Tech - odometer / speedometer same part?
View Full Version : odometer / speedometer same part?
nosliw
08-24-2011, 07:34 AM
hey
I would like to know if in the 5th generation the odometer gear and speedometer gear are the same part?
are they located in the transmission linked to the dashboard with a cable ?
:confused:
DietCoke
08-24-2011, 07:21 PM
There is no gear for the odo. It's all electronic.
They work seperately. You can unhook the speedo and your odo will still tick.
nosliw
08-25-2011, 02:29 PM
ok so where it tooks the speed ? in the transmission ?
DietCoke
08-25-2011, 07:24 PM
It's recorded in the BCM and broadcast to the display on the cluster. Its a combination of the VSS in the trans, and the abs sensors at the wheels, and is tied into the tune of the car.
