Ls3 head flow numbers
Old 08-24-2011, 07:37 PM
matrixiskool's Avatar
Default Ls3 head flow numbers
Ive looked everywhere, but I don't see any consistent Ls3 flow numbers. What im looking for is: flow numbers for PRC ls3, stock ls3(0821), GMPP ls3, SDP CNC ls3 and any other ls3 heads at comparable bores. I just saw someone that showed their flow for ls3 heads on a 4.030 bore and compared it to Texas Speeds CNC heads but the stock 4.030 flowed better..., this is why Im looking for some accurate numbers.
Old 08-28-2011, 04:56 PM
Seriously no one is interested in this?
Old 08-29-2011, 05:52 PM
COPO9560's Avatar
Trying to find good data on a 4 inch bore is tough. Many list numbers on a 4.125 that makes them look better. Look at MAST, I believe their small bore LS3 offering is on a 4 inch bore.
Old 08-30-2011, 01:09 AM
CAMSTER's Avatar
Default ls3 heads...
Intake ports on ls3 flow 319cfm out of the box, the intake port volume is 260cc.
Old 08-31-2011, 09:16 AM
mebanestang's Avatar
google stan weiss head flow. have just about every head imaginable flow tested. see if that helps
Old 08-31-2011, 11:18 AM
LS6
LS6's Avatar
Please see the attached hoping this will help...
As advice, the flow number will be usefull if you know the cross section area of the runner to determine the velocity.
The key is velocity.
I wish if they could post velocity (m/sec) instead of flow (m3/sec)
Thanks
Quick Reply: Ls3 head flow numbers
