Lq4 ls1 performance parts list.
These are the performance parts imm order this winter.let me know if im going in the right direction to have a great daily sreet / track car.My goal is to have between 425hp to 500hp with good gas mile's.
1.FAST LSXR INTAKE MANIFOLD # FST-146302 $949.95
2.TRICK FLOW THROTTLE BODY 1in SPACER#TFS-3062002 $65.95
3.FAST THROTTLE BODIES #FST-54102 $494.95
4.FAST LSX HIGH FLOW BILLET FUEL RAIL #FSX-146028 $187.25
5.COMP CAMS LSR SERIES HYDRAULIC ROLLER CAM
INTAKE 0.617/EXHAUST 0.624 . #CCA-54-459-11 $396.95
6.COMP CAMS SHORT TRAVEL RACE HYDRAULIC ROLLER LIFTERS
#CCA-15956-16 $536.95
7.COMP CAMS VALVE SPRINGS #CCA-26926-16 $269.95
8.HARDLAND SHAFT MOUNT ROLLER #CSP-SLS18 $379.95
9.SLS PERFORMANCE LS1 PORTED OIL PUMP #SLE-55001 $185.95
10.MOROSO BILLET ALUMINUM OEM ELRCTRIC PUMP #MOR-63566 $439.95
11. McLEOD STEEL FLYWHEEL #MCL-460530 $345.95
Cam-call eps$ 425
springs patriot duals $255
used fast 92mm 800
fast92 tb 450
ls7 lifters 110
stock rockers 100
melling oil pump 100
243 heads 500
ls2 t/c
36lb inj
thats all you need to make
mid 400's. You dont need an el waterpump, a tb spacer, those rediculous lifters wtf at 540 bucks!!! I made 450 with bolt ons and a cam, no head work and a 346 ci motor, you have 364 which is an instant advantage. Dont overthink these motors it extremely easy to make big power with good street manners.
used fast 92mm 800
fast92 tb 450
ls7 lifters 110
stock rockers 100
243 heads 500
ls2 t/c
36lb inj
Part numbers??? Serious Teddy. Just search for the parts he listed and they will all come up. You are attempting to waste money, go with his recommendation and save some coin.
