98 formula hard to start?
Old 08-25-2011, 01:10 PM
Phoenix64's Avatar
Default 98 formula hard to start?
I have a 1998 formula that is hard to start, it cranks for probably 3-7 seconds before it lights off.
Seems to be running alright otherwise.
Thanks for any help.
Old 08-25-2011, 02:27 PM
Phoenix64's Avatar
update, there is no fuel pressure at the rail with the engine off.....
priming it makes no difference to it starting.
Old 08-25-2011, 02:39 PM
mike171562's Avatar
What is your fuel pressure when you turn on the key? It sounds like your Fuel pressure is bleeding off.
Old 08-25-2011, 02:43 PM
ds98formula's Avatar
Any lights on?
Old 08-25-2011, 03:26 PM
How old is fuel filter
Old 08-26-2011, 02:52 AM
Phoenix64's Avatar
I will try to get a fuel pressure gauge today, the fuel filter is about 4 years 20,000 miles.
Old 08-26-2011, 02:54 AM
Phoenix64's Avatar
If the puel pressure is bleeding off, what is the fix?
If you push in the schrader valve, it makes a gurgling noise, but no fuel whatsoever comes out.
Old 08-26-2011, 03:24 AM
myk
myk's Avatar
The fix is replacing the pump and or the pump assembly-I'd just do the whole assembly if you're going to be in there anyway.
Goddamn electric fuel pumps...
Old 08-29-2011, 01:23 AM
HumpDay's Avatar
check fuel pressure at prime and report back... could be a bad fuel pump or a clog in the lines/filter
Old 08-29-2011, 01:24 AM
1Psycho's Avatar
My guess goes to fuel pressure regulator or the little line off it as well
