aftermarket upper shock mounts?
i just did new shocks, kyb agx, and while doing them i replaced the upper shock mounts on the fronts. this was about 3 weeks ago, the new shock mounts are completely destroyed, the rubber is completely torn and the shock is wiggling around inside it making a bunch of clunking. im guessing because they were autozone parts. does anyone know where i can get some aftermarket upper shock mounts? thanks a bunch guys
LS1Tech Premium Sponsor
Definitely make sure you use this piece that sits on top of the strut mount. It is used to disperse the load on the shock mount and when it is not used it will destroy a shock mount very quickly.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
im almost positive i installed those, they have to go on otherwise you cant tighten the shock since there isnt enough threads to snug it down all the way right? im guessing this is probably trashed too, i havent taken it completely apart yet and wont until i get the new mounts, so i think i need these too but im not sure. does anyone know the technical name for it to order it, or know where to get them?
https://ls1tech.com/forums/15198654-post3.html
You can get all that stuff at rockauto.com
