Small Block & Big Block Chevy Specific - SBC dying when I blip throttle in gear
Camaro350Z28
08-25-2011, 03:15 PM
Whenever i just stab the throttle in gear and let off my truck dies. Its a sbc with 600 edelbrock on it. not quite sure what to start checking never had this issue before
cambirdracing
08-25-2011, 03:57 PM
How long has it done it? Have you made any changes before it happened? Did it start all the sudden? Possibly after a fillup? I would start with throwing away the carb and getting a good Holley for it and check your timing.
Camaro350Z28
08-26-2011, 12:57 AM
ya i just made some changes. heads and intake. im not a fan of edelbrock carbs, its just on my gmc 4x4 so i thought itd be ok for wheeling.timing is about 12-14 with vacuum advance unplugged and plugged
cambirdracing
08-26-2011, 06:30 AM
Check for vacuum leaks. A can of carb cleaner will do the trick. Spray it all around the base of the carb and around where the intake bolts to the heads. If idle changes, then that's where your leak is at.
64nova_wagon
08-26-2011, 01:31 PM
what size engine, Heads? You should have 30-36 total timing with vacuum at 2500rpm. Might have stuck weights, or just need jetting..
Camaro350Z28
08-26-2011, 03:26 PM
its just a 350. vortec heads, vortec edelbrock intake. i got timing at idle at 12-14 and dizzy should give 18-20 on advance.
64nova_wagon
08-26-2011, 04:54 PM
Hmmn. You didnt change thecam?> you sure the wires arent off by 2?
Camaro350Z28
08-26-2011, 06:07 PM
oh sorry, yes i put a cam in it, comp 270h
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
