radiator for front mount setup
Old 08-25-2011, 03:34 PM
273sunsetZ's Avatar
Default radiator for front mount setup
I was planning on just using the stock radiator with pusher fans but its been getting around 220* in the summer heat and I really don't want to beat on it while its that hot. What's a good radiator I can get to fit in the stock location? I have 2 weeks to finish this for lsfest so need to get one ordered asap.
Old 08-25-2011, 07:30 PM
black98ws6ta's Avatar
What pusher fans? Do you have them sealed well? The LT1 radiator is thicker then the LS1 radiator but the same demensions otherwise.
Old 08-25-2011, 10:25 PM
273sunsetZ's Avatar
I've got VDO pushers on it now, on the bumper side. I might try and fit them on the engine side once i get the turbo blanket in this weekend and see if that helps, just not sure at this point.
Old 08-26-2011, 07:25 AM
Strokinit383's Avatar
https://ls1tech.com/forums/forced-in...icle-here.html
Quick Reply: radiator for front mount setup
