LS1 stumbles and tach flutters (video)
Old 08-25-2011, 04:26 PM
1970RSZ28's Avatar
Default LS1 stumbles and tach flutters (video)
Just as the tiltle says... Its in a 70 camaro with a t56. 99 and up wiring harness. I was wondering what sensor controls the tach? Is it the reluctor wheel? Thanks guys
or
http://www.youtube.com/watch?v=ZNOdfp-Xbx8
Old 08-26-2011, 02:45 PM
Project GatTagO's Avatar
Received 1,384 Likes on 873 Posts
Where are you picking up the tach signal? I had to use a pull up resistor with my Autometer tach for it to even work. You may need one to stabilize the tach needle.
Andrew
Old 08-29-2011, 02:50 PM
1970RSZ28's Avatar
Im picking up the tach signal from a wire coming directly from a PSI Wiring harness. I'll check this pull up resistor thing thanks!
Old 08-29-2011, 06:39 PM
Old Geezer's Avatar
Same here w/ the retro Sun tach in my 55.
Old 08-29-2011, 07:27 PM
gMAG's Avatar
Not sure if I'm misunderstanding the trouble. Does the engine stumble AND the tach flutters, or is it only the tach fluttering (and making the engine look like its' stumbling)?
Old 08-29-2011, 07:34 PM
gMAG's Avatar
If it's only the tach that's misbehaving, here is the tach ckt remedy, courtesy of FastKat-after you redirect to this thread, scroll down about 75% http://www.buyrcars.com/jag.htm
Quick Reply: LS1 stumbles and tach flutters (video)
