Gen 5 Camaro Racing Tech, Results - Lingenfelter Race Engine Dyno Video!!!!!
Kevin@Lingenfelter
08-26-2011, 07:54 AM
Lingenfelter 358 CID LSx flat plane crank race engine for our new white Gen V Camaro SS. This engine is putting out 621 horsepower @ 9,000 RPM running NA. Below are several pictures of the build process. Click here (http://www.lingenfelter.com/LPEforumfiles/showthread.php?t=904) to watch the video of this engine running on the dyno!!! :judge:
http://www.lingenfelter.com/LPEforumfiles/picture.php?albumid=49&pictureid=1443
http://www.lingenfelter.com/LPEforumfiles/picture.php?albumid=49&pictureid=1440
Never Satisfied
08-27-2011, 07:55 AM
Wow, impressive for sure....thanks for sharing! What do you expect the output to be with the 76mm?
Fb0dy0nly
02-03-2012, 05:20 AM
Why such a small turbo? I know its not that "small" but something like an 80 or even 88 would seem better suited no? Sticking with smaller for better spool down low?
What rpm does that thing idle at?
How is low end with the flat plane? Is there no power till 5k rpm?
Ryan@Lingenfelter
02-03-2012, 08:37 AM
This motor is for an LSX Real Street car. The class is limited to a 76mm turbo. The car launches off the trans brake at 5,000 rpm.....
