Poor mans slipper clutch
has anyone tryedto shim there non adjustable clutch psi plateto the flywheel to try and drop the clamping psi thus getting a lit bit of slip out of the clutch. To help get a car off the line?
I think that's a great idea, and I would love to hear from someone who has done it.
I've had good luck in other cars with Centerforce dual friction clutches having some give, but I've never tried a Centerforce in an LS application. Also, never tried the Centerforce with more than about 500 RWHP in a 3200 lb car.
Keep us posted man, that's a killer idea.
CenterForce sucks.....
I dont think regular discs have enough friction to work like this, however if you could get a true sintered iron disc, maybe....
if you have a better setup that will help me 60 foot better i am all ears sir.
Rob
Also here are vid's of the problems i am up against.. here is the car leaving okay
http://i82.photobucket.com/albums/j2...k/2f711037.mp4
http://i82.photobucket.com/albums/j2...k/e69655e9.mp4
http://i82.photobucket.com/albums/j2...k/d0e00c5c.mp4
And this last one is me fighting the setup with new found power
Badd SS i have read that it should be a true sintered iron disc.and is this type of setup what you were trying before yours let go??? and it sucks but i thought u and me were going to be fighting for some good sbe 346 times
Billy i have a http://www.kaltechtuning.com/index.p...roducts_id=200
Rob
Rob
If you could find the money you'd be better served going with our Soft Lok unit p/n 4914-00-07.
using a shim.... rob, weren't you with chris at last year st. Louis And saw how that worked for me
anyone dose it with the hydraulic, a good adjustable electronic valve and a timer. I know some evo guys bought the stuff and got it set this up last year. I never heard how it worked.
Breaking in my RXT, I like it alot so far.
and you shim your clutch for the LSx shoot out. and i will have to ask the guys at ams about the setup your talking about
Nice vid's - I see the car has hoosiers on it now
Rob I don't know how grabby the Tex is or if you have a tick master......but have you tried to move the engagement/release point around? I found giving the rod more length and moving the engagement up gave me a little me a little more pedal - and made it easier to slow down the hit. Makes it easier to shift too - just bump the clutch and your done. My Monster is stupid grabby and the car doesn't really start moving until it's released fully.
