Dumb question...can you hear your turbo under regular acceleration
Old 08-26-2011, 08:21 PM
evo462's Avatar
Default Dumb question...can you hear your turbo under regular acceleration
This is probably a dumb question, but I was wondering about it earlier and have never ridden in a turbo car before. Can you hear your turbo "whistle" under normal acceleration? From a stop, putting around town, etc? I can hear them on diesel trucks so figured...maybe? I had a Pontiac Grand Prix GTP with the M90 supercharger that you could hear very slightly under regular acceleration.
My turbo is a Turbonetics TC78, for what it's worth.
Old 08-26-2011, 08:41 PM
got-a-ls1's Avatar
install it and find out!
im getting ready to install mine so i cant tell you yes or no..
Old 08-26-2011, 09:22 PM
MillsMotorvation's Avatar
Havent tune the LQ4 yet, but on my 87 Grandnational I can hear the 76 all the time when riding around.
Old 08-26-2011, 09:37 PM
jridenour31's Avatar
I've never been able to hear it just cruising down the road but as it nears zero vacuum I can hear it start whistling pretty good. You don't have to be in boost to hear it, as long as the turbo is spinning fairly quickly you'll hear it, like lugging the engine while accelerating or going uphill in overdrive.
Old 08-26-2011, 09:52 PM
turbo iroc's Avatar
I had a t72 on my SBC 383 thing whistled lke crazy with the exhaust cutout open. Now I have an 88mm on my 402 lq9 and its really quiet. I'm kinda upset about it actually. I think its because this Turbo has a huge exhaust wheel and the rpms of the Turbo are much lower than the t72. Its the turbine side that you hear when cruising, when you lay into it you hear the high pitched jet engine sound coming from the compressor. Here's a dyno vid you can hear cruising whistle then boost whistle.
http://www.youtube.com/watch?v=ZqcHDKdC7cs
Old 08-26-2011, 11:23 PM
buick_lsx's Avatar
yes...but once i go wot all i hear is exhaust lol
Old 08-26-2011, 11:56 PM
yessir's Avatar
not sure what it sounds like from the outside but from in the car all i can hear is angry motor noise lol, i cant hear the turbo, the wastegate or the bov. only time i can hear it is when i hit the two step and let the turbo downspool. lq9- pt88- 4 inch open downpipe
Old 08-27-2011, 04:27 AM
Nitroused383's Avatar
With open cutout I can hear the thing spool up all the time I am accelerating. If I'm going up a slight grade it just sits there and whistles. With my cutout closed going through my slp dual dual you cannot hear the turbo at all unless you really get into it. The precision 76 I run now makes a lot more noise than my TC76 did.
Old 08-27-2011, 08:18 AM
98Camarod's Avatar
That was going to be my comment. On my old setup it was just an open down pipe. On the new setup it will be two open downpipes
Old 08-27-2011, 09:25 AM
Fbodyjunkie06's Avatar
When I am going up a hill in 4th at 45-50mph loading the motor up with the converter locked is the only time I hear mine "whistle". I can also hear it in 3rd when I am slowly accelerating on the on ramp letting the boost slowly come in from vaccum to boost I can hear it then. Once I floor it though I can't hear any turbo, all exhaust then the BOV when I let off. My car the BOV probably doesn't even open when I shift since I am an auto car.
Now at the track on the line when I am footbraking it you sure as hell can hear it, and especially when I go from the footbrake to the transbrake it really starts singing it's whistling melody. Soon as the button releases though and the motor goes over 4000rpm it's only exhaust noise I can hear.
Old 08-27-2011, 01:29 PM
Fondle's Avatar
i can hear my turbo spooling everytime for sure, even without getting into boost, you can hear it whistling
i have 3.5" downpipe with no muffler exiting right before the axle
Old 08-27-2011, 02:01 PM
I guess I should add that I have a dynomax bullet in the I-pipe(3") and a dynomax ultra magnum race muffler(1 chamber) 3" inlet 2.5" dual dual otl outlets. I need a cut-out bad. I bet I'd gain close to 50rwhp with a cut-out dumped off my 3.5" downpipe and I bet it would spool super quick.
Old 08-27-2011, 02:37 PM
evo462's Avatar
I'm planning to mate my downpipe up to my "Borlamouth" system (Loudmouth + Borla XR1) so it's not too loud...an electric cutout might be worth doing though.
Do those QTP units seal up pretty well?
Old 08-27-2011, 04:34 PM
rotary1307cc's Avatar
The biggest factor will be if the compressor housing is a ported anti surge design or not
Anti surge housings make alot of noise hence why the diesels are all so loud
Talking compressor noise not turbine out the exhaust
Old 08-27-2011, 06:35 PM
MaxxMitchell's Avatar
Usually yes you will hear it with any decent throttle, like 30-40% and higher. If open DP the TCs are pretty loud through the exhuast.
Old 08-27-2011, 06:40 PM
I wonder why that is?
What size turbine wheel did you T6 76mm have? Was it a BW unit?
Old 08-27-2011, 06:51 PM
tripblackls1's Avatar
i hear turbine under part throttle
might be because of this
i also using a anti-surge comp housing so getting close to 0 vac i get comp noise
oh and a small idle clip for those interested in how the bumper exits sounds
http://youtu.be/KYyuEp5fiPk
Old 08-27-2011, 06:52 PM
Like the wheels! Mine are chrome, 17/18's???
Old 08-27-2011, 06:58 PM
18x10.5 on all fours 295/35 fronts 305/35 rears
Old 08-27-2011, 08:14 PM
How well do the 295's fit? Do they rub lock to lock? I have the same size rear tires and wheels, but I have 17x9.5" in front with 275/40's.
Quick Reply: Dumb question...can you hear your turbo under regular acceleration
