Anyone used a McLeod Slik Stix Shifter for 4th Gen F-Body???
Old 08-27-2011, 01:50 PM
drain89's Avatar
Default Anyone used a McLeod Slik Stix Shifter for 4th Gen F-Body???
Correction: Quik Stik Shifter. These use Belleville washers instead of a spring for centering. Supposedly they do not lose tension like a spring. I'm considering buying one, but only if it's a smooth and quiet shifter like the MGW. I don't want a noisy, notchy shifter like the Pro 5.0.
Anybody on here used one? How's the feel? Noisy?
Old 08-27-2011, 06:10 PM
SWeiser31's Avatar
Where'd you see this at? They don't have anything on Mcleods website for the 4th gen F-body. At least not that I see.
Old 08-27-2011, 06:21 PM
coolmanvette75's Avatar
Agreed. Ive never heard of this shifter before...
Old 08-27-2011, 06:22 PM
drain89's Avatar
http://www.mcleodracingdealer.com/mcleod_pricesheet.pdf
Page 74 and 75.
Several options for it: Straight up, offset left, right, forward, backwards, or various combinations in different length offsets. They are also available with positive stops, but I'm told that's not necessary.
Old 08-27-2011, 06:32 PM
drain89's Avatar
This appears to be what I'd want if using a UMI short stick: 82-100-004-08 SHIFTER T56 1993-02 CAMARO, STRAIGHT UP NO STOPS $250.00
BillyM (McLeod Rep on here) recommended P/N 81-421-264-08 so I'd check with him first before ordering anything.
Here's an exploded view of one:
Old 08-27-2011, 07:03 PM
drain89's Avatar
Red Roberts (Former Owner of McLeod) also lists it on his site:
http://redrobertsinc.com/index.php?o...2003&Itemid=66
Old 08-27-2011, 08:13 PM
mean_greenZ's Avatar
My pro 5.0 is not notchy or noisy.
Old 08-27-2011, 09:35 PM
drain89's Avatar
Mine was! I had both it and a Hurst Billet Plus. I liked the Hurst better. I heard the MGW is really quiet, and smooth. I wonder how this McLeod compares to a MGW? Surely somebody on here has used one.
Old 08-27-2011, 10:29 PM
HioSSilver's Avatar
Mine is not notchy at all. It could be a little quieter.
Old 08-29-2011, 11:49 AM
Billy M's Avatar
I actually have one in my 3rd Gen Camaro with a LT-1 6 speed. Pretty nice shift and not noisy at all. But i'm a little biased so take it with a grain of salt.
Quick Reply: Anyone used a McLeod Slik Stix Shifter for 4th Gen F-Body???
