Help me with my stance looks cool on vdubs but not this ahhhhh
Old 08-28-2011, 01:21 AM
donati98ta's Avatar
Default Help me with my stance looks cool on vdubs but not this ahhhhh
So i got my car about 2 months ago. love it overall but GA damn whats up with this front stance ?
They look like the c5 replicas from OE Wheels.
Fronts appear to be 17 x 9.5
But for some godawful reason there is a 2 inch spacer !!!!! wtf ?
Car is lowered on eibachs i was told.
From the looks of things i have about an inch to spare before it rubs
If you have a 1998 -2002 trans am with these wheels please post pictures and tell me how you solved this problem i am having !!! Im going ape **** over here
Need my car to stop looking like this
thanks
_ dante
Old 08-28-2011, 01:43 AM
donati98ta's Avatar
comone guys imput
Old 08-28-2011, 03:01 AM
whytryz28's Avatar
Input on what? Remove the spacers.
Old 08-28-2011, 03:57 AM
Captain Double Post
BOBS99SS's Avatar
lol,op do you not know that you can take the spacers off?
Old 08-28-2011, 08:18 AM
carlos64030's Avatar
LMFAØ!!!
Old 08-28-2011, 08:20 AM
babbage1109's Avatar
A 17x9.5 wheel will fit in your well without a spacer. Take it off you r tard
Old 08-28-2011, 09:06 AM
donati98ta's Avatar
but i was told it will rub and thats y the spacer was on in the first place... and by looking under the car when its on a lift it looks like i only have an inch
could these for whatever reason be a 8.5 inch wheel ?
Old 08-28-2011, 09:09 AM
Scott97LT1's Avatar
BFH mod + remove spacers = voila!
Old 08-28-2011, 09:16 AM
White94Bird's Avatar
I run a 17x9.5 inch wheel from the same people, doesn't rub, so take them off.
Old 08-28-2011, 09:50 AM
There is no place on the front to use a hammer. Unless you're going go hammer the plastic shield? Or your spindles and bend them. Don't use a hammer on the front of your car. There are tons of guys using 17x9.5 wheels on here without rubbing.
Old 08-28-2011, 10:29 AM
Parasoth's Avatar
The reason why it looks like it will rub on a lift is because your suspension is not loaded. When your suspension is loaded with the car on the ground, you will see it clears the spindle cleanly.
Old 08-28-2011, 10:43 AM
Camaroking1996's Avatar
If you are rubbing with a 17x9.5 wheels your are running a really really low suspension setup.
Old 08-28-2011, 11:24 AM
donati98ta's Avatar
ill update this after i do my headlight motor gears ...
Old 08-28-2011, 01:18 PM
DWake's Avatar
Yeah I have 18x9.5 with 265/35, offset is +56 and they are tucked in and don't rub
Old 08-28-2011, 02:06 PM
94lt1white_bird's Avatar
this must be some sort of sick joke....
Old 08-28-2011, 02:51 PM
Deviant LS1's Avatar
Take the spacer off and get a wider tire so you get rid of the stretched look.
Old 08-28-2011, 06:24 PM
donati98ta's Avatar
just took the wheel off its a 17x 9.5 with + 45
Old 08-28-2011, 06:25 PM
RoidedSS's Avatar
get rid of the spacer, put the rims back on and see if they rub...if they rub, get a smaller spacer then what is on there. Plenty of people run 17x9.5 inch rims including myself without any issues at all.
Old 08-28-2011, 06:29 PM
1995blacktattop's Avatar
I've had 17x9.5 OE wheels ZR1s on my car for over 6 years with no rubbing.
Old 08-28-2011, 06:34 PM
donati98ta's Avatar
offset is a + 45 but its got this massive papper weight spacer 2 inches thats + another 50 mm. so its + 95 wtf
i can keep the wheels then do a + 10 mm spacer be at +55 and it should do fine ?
would i need longer studs for this to happen ?
based on this thread i need to fall in between 50- 56
https://ls1tech.com/forums/wheels-ti...must-read.html
Quick Reply: Help me with my stance looks cool on vdubs but not this ahhhhh
