Northwest Members - Can anyone help me out with HID fog install?
MEGATRONSS
08-28-2011, 12:33 PM
Having trouble on how to install 6k HID's in my fog lights(camaro).
The problem I'm having is that the connectors going in to the ballast don't match the harness from the car.
There are two connectors on the cord going into the ballast, but the harness that the old fog bulb went into(that should connect to the ballast) is just a single connection and I can't or don't know how to make them connect.
Does this make sense to anyone? Any help would be great on this, I really don't feel like paying someone an hour of labor to do it
SsSteven
08-28-2011, 12:53 PM
Come thru the pad again, I forgot all about the hid issue you were having! The other wire might just be a ground? We can unplug the wires coming from the stock fogs and see what kind of voltage is going out. I'll also research how those things are supposed to be hooked up.
MEGATRONSS
08-28-2011, 03:34 PM
Soundsgood I'm gonna text you
bad_408_vert
08-29-2011, 12:22 PM
I'm trying to add HIDs to my fog lights.
Did you have to do any modification to make the HID bulbs hit in the fog housing. My 894 bulbs seem too tall & hit the dome of housing?
