A/C problems compressor wont turn on
Old 08-28-2011, 01:23 PM
95_Z-28_runner's Avatar
Default A/C problems compressor wont turn on
i have a 1995 Z-28 and with max a/c on it blows hot air and the compressor does not engauge. thinking its a relay i jumped the relay for the A/C compressor. sure enough it turned on but the tepature remained the same i have not put a full charge in the system yet, but i wanted to know if i should check anything else that might cause me to evac the system anyways before i charge my system.
thanks very much
Old 08-28-2011, 01:33 PM
96TransAmboosted's Avatar
Is there enough freon in the system for the compressor to engage? Have you hooked up gauges to see what the high/low pressures are yet? You need to start there first and this will tell you what's going on. Tell me what the pressures are and ill let you know what the issue could be.
Old 08-28-2011, 01:59 PM
OK thanks
Old 08-28-2011, 09:06 PM
SoxXpupPeT's Avatar
like said, check to see if theirs coolant in it first. if not then check to see if powers getting to the connector
Old 08-30-2011, 02:34 AM
z28tommy's Avatar
i have the same problem i switched the relay and the compressor didnt turn on i charged the system and nothing any sugestions on what it is
Old 08-30-2011, 03:46 AM
whytryz28's Avatar
Gotta make sure there is enough freon in the system first like stated. Buy a gauge and check it.
Old 08-30-2011, 09:51 AM
If the compressors not turning on then how do you know there is enough freon in the system? Without the compressor engaged then the pressures would be off and sometimes the system wont take freon witout jumping he compressor. I hope your systems were vac down because air in the system could prevent the proper amount of freon to be added and prevent the compressor to engage due to the lack of freon. Gauges are need to diag this system
Old 08-30-2011, 01:03 PM
myltwon's Avatar
Got the same problem here, a/c system is fully vacuumed and charged but compressor only engages when the relay is jumped. Already changed the orafice and pressure switch, kind of at my wit's end with it.
Old 08-31-2011, 10:42 PM
formula vincent's Avatar
could be a bad pressure switch.
Quick Reply: A/C problems compressor wont turn on
