DOD/VVT delete necessary?
Old 08-28-2011, 02:04 PM
5.3Lnova's Avatar
Default DOD/VVT delete necessary?
i have 5.3l lmg from an 09 tahoe and i am wondering if i need to delete dod and vvt. i have read and looked up kits but i have the motor in the car and have started the motor before i knew about the deletes. the motor runs ok for the most part it only runs on 12 volts instead of regular 13-14 range. the motor also has a steady idle but sometimes has a hiccup and will run up and down about 200-300 rpm but smoothes out if i give it some gas i believe this is caused by low voltage. i also don't have 02 sensors yet. so my question is are the dod and vvt functions causing the trouble and if not why should i buy the delete kits if the motor runs half way with them unplugged.
thanks, robert
Old 08-28-2011, 07:43 PM
S10xGN's Avatar
They're not causing your issues. It seems you have full factory programming and the motor runs, so if you're OK with it being stock, then leave it as-is.
Old 08-28-2011, 07:49 PM
5.3Lnova's Avatar
yes i do have a factory tune. i did not think the problems were caused by the dod/vvt but if the motor runs why should i get the delete kits? is there an advantage or a reason to get the kits?
thanks, robert
Old 08-28-2011, 07:54 PM
S10xGN's Avatar
thanks, robert
Your better off keeping it. The only reason for deleting is aftermarket cam/valvetrain parts and high RPM usage.
Old 08-28-2011, 08:03 PM
5.3Lnova's Avatar
well i am planning to get the motor dyno tuned when the car is done so was wondering if the deletes would help. thanks for the info.
thanks, robert
Quick Reply: DOD/VVT delete necessary?
