Need help removing pinion bearing stock 10 bolt
Old 08-28-2011, 02:10 PM
Red99T/A's Avatar
Default Need help removing pinion bearing stock 10 bolt
Okay, I can't figure out how to get the old pinion bearing out to put the new one in. I have the driveshaft dropped out and the seal off, but can't get the bearing to move. Is there a special tool or trick to getting it out? Trying to avoid dropping and disassembling the rear at all cost. Thanks in advance for any help!
Old 08-28-2011, 08:50 PM
HoLLo's Avatar
Pinion bearings need bearing pullers and a hydraulic press to remove properly. On a buddy's car, once we had everything out, the only way to remove the stock pinion from the rear itself was a big fuggin hammer!
Old 08-28-2011, 09:41 PM
JaYZeig's Avatar
you need to pull the rear apart to get that bearing out, the bearing is pressed onto the pinion gear, and the only way to get the pinion gear out is through the differential.
Old 08-29-2011, 03:52 PM
01ssreda4's Avatar
Take the car to someone qualified....
Old 08-30-2011, 02:24 PM
ortiz11b's Avatar
need to pull out the carrier and use a long punch to knock it out.. i just rebuilt the whole rear end... i took it out and placed it my garage and took my time... good luck
helpfull video..
http://youtu.be/jh25DUyCWY8
Old 09-04-2011, 04:46 PM
whytryz28's Avatar
Just a quick question but is the pinion out of the rear end?
Quick Reply: Need help removing pinion bearing stock 10 bolt
