Simple Pulley question please help
The underdrive pulley will cause the supercharger pulley to turn slower. If your supercharger pulley is turning slower, you will be moving less air. Up to a certain point, less air means less power (until heat becomes your limiting factor.)
So the answer is - putting on the underdrive pulley will probably reduce your power.
