Cluster swap
Cluster swap
My tach is not working in a 99 T/A so I took a cluster out of my friends 2000 T/A to test if cluster i s the problem and the car only cranks and won't start with loaner cluster but it still starts with the broken one. What do I have to do to let it work with loaner cluster.
I took the complete harness out of a 99 and did an LS swap on 95, the engine, interior harness and the bcm and cluster are all original to them selves, I have no Idea if the tach was broken I just finished this swap and started car runs fine except for tach so I was swapping cluster to see if that was the problem but then I ran into the no start with the other cluster,
Also I went to an exhaust shop to get some work done on it yesterday and the car would not start when I went to pull in so I opened the hood and shook wires back by cam sensor and then it started the scanner showed a cam sensor code so maybe I do have a problem in the harness by cam sensor, the sensor is brand new from GM so 'm hoping its fine.
Yeah buddy, that's what I was thinking. Without the proper signal from the cam/crank the PCM will guess and either be right or 180 out. So it will start sometimes, and backfire other times. You have a break in the harness somewhere, or a bad cam position sensor, or a worn out magnet on the cam, or the cam bolts came loose from the sprocket and the cam is walking.
Im trying to get my cluster to work....i put everything from a 98z28 under hood into a 00z28 i didnt change wiring under dash tho and i left the traction control abs module in the 00 as well....my gauges r not working in the 00 with the 98 motor tranny n ecu how can i fix this problem someone plz help me i need gauges theyre important when smashin on mustangs lol!!
