Canada204
08-29-2011, 06:55 PM
Alright First Time at the track was nervous for sure wasn't being gunho whatsoever.
For starters had 3/4 of a tank of fuel And I think I was Shifting into 5th
Reaction .9830
60ft 2.0041
330ft 5.4159
et 594ft 7.7420
1/8et 8.2577
1/8mph 87.25
1000 et 10.6971
1/4et 12.7340
1/4mph 110.82
Running on Nitto 555R 18psi 275/40/17 No Traction Launching at 2500rpm
MODS Are
Hooker Long tube Headers
Texas Speed True Dual exhaust
MTI Clear Lid
SLP Smooth Bellow
Comp 231/237 .598 .598 114 LSA Camshaft
TSP Hardened Pushrods
PRC double springs good for .650 lift
LS6 Intake Manifold painted red to match the car
Rebuilt T56 Transmission with the following parts-
Steel 3-4 shift fork
Bronze pads
Blocker rings
LS7 Clutch
LS2 Flywheel
Moser 12 bolt with 33 spline axles, C-Clip eliminators, and 4:10 gears
1350 yolk/u-joint
Alum Driveshaft
BMR torque arm
BMR SUBFRAME CONNECTORS
Hotchkis panhard bar
BMR lower control arms
Dyno tuned 360RWHP/355 RWTQ AFR's- 11.0
Wanting to purchase Hoosier Drag Radial or M/T ET Streets 275/40/17 or go full slicks on 15 inch rim
Next time I go to the track im going to do this
1/4 tank of fuel 94octane with ethanol or 91octane no ethanol or Mix either with race fuel?
Remove Rear Seat Jack and spare tire.
Air up the front tires to 40psi Cold
Empty Washer Fluid
New Tires
Try Different Shift Points
Any Launching Tips?
11s Possible
Reaction .9830
60ft 2.0041
330ft 5.4159
et 594ft 7.7420
1/8et 8.2577
1/8mph 87.25
1000 et 10.6971
1/4et 12.7340
1/4mph 110.82
MODS Are
MTI Clear Lid
SLP Smooth Bellow
Bronze pads
Blocker rings
LS7 Clutch
LS2 Flywheel
1350 yolk/u-joint
Alum Driveshaft
BMR torque arm
Empty Washer Fluid
New Tires
Any Launching Tips?
11s Possible
