t04e too small?
Old 08-29-2011, 07:20 PM
tc3
tc3's Avatar
Default t04e too small?
This turbo is a t04e that i cant find specific specs for however ita a t4 and 3in dp. 3 inch inlet and 2 inch outlet on intake side. And a 50 trim inducer.
Is this going to be a restriction? And how much of one?
Thanks!
Old 08-30-2011, 09:57 AM
FourG63 97GST's Avatar
had one on my 2.0L, what is the turbine A/R?
Old 08-30-2011, 11:01 AM
tc3
tc3's Avatar
I wanna say 1.10.. but ill verify after work.
Old 08-30-2011, 03:18 PM
Sarg's Avatar
Short answer is yes, it is more than likely going to be too small. That turbo is just not capable of flowing much air at all! I have seen 2.5 liter cars max these out
Old 08-30-2011, 05:45 PM
tc3
tc3's Avatar
Ok. Kinda what i Expected from searching about it. Soo 7 psi with this turbo wont do close to what the same psi with bigger?
I thought the lack of flow would result in low pressure but occasionally it will go to 10(new wastegate coming soon)
Old 08-30-2011, 06:16 PM
Sarg's Avatar
It is not so much that it won't do it, so much as the fact that it will be WAY out of its efficiency range very quick. Out of its efficiency range means 2 things:
1. It is going to rapidly be inefficient and will produce a hotter and hotter charge on the compressor side.
2. The turbine wheel will start becoming a choke point and drive up backpressure in the exhaust.
So, can it be done? Yes. Is it a good idea? Not really.
Old 08-30-2011, 06:58 PM
tc3
tc3's Avatar
Ok. Soo that explains the lack of power... Time for a t76 i guess...
Thanks for the info
Old 08-30-2011, 07:41 PM
Sarg's Avatar
That is about a 400-450 max hp turbo before it starts getting pushed a bit farther than it should be taken. People push all kinds of turbos beyond what they should be...but it is not good for the turbo or the motor. It can hold boost, but at the expense of spinning the turbo way to fast and going outside its efficiency range.
Old 08-30-2011, 08:26 PM
tc3
tc3's Avatar
hmm... Well the car isnt doing that... I mean it trapped 109mph at 4psi... had some minor boost leaks and clutch seemed to slip slightly but did 112mph before. regardless no more messing around... turbo is to be gone.... That fake ptk kit was tooo much of a pita to let it suffer from a restrictive turbo...
Thanks again
Quick Reply: t04e too small?
