New LS1 Owners - Newbie Tech - how well does the MAF translator work
slik98z
03-05-2004, 01:47 AM
Im a little worried as i dont have enough dough to get a dyno right now and im adding lt's in a few days. Shoul di pick up one of the maf translators to help zero in my a/f ratio jsut in case its off a little bit or should the stock pcm be able to adjust enough for me? Im not looking for top performance, mostly i just wanted a little extra power but the headers are being added mostly for exhaust note.
Thanx
Travis
samz28
03-05-2004, 07:23 AM
well without a wideband how you gonna know your air fuel? o2 sensors really aren't that accurate. ESP if you go LT/ORY air passes right on by them o2's a bit faster than with cats.
4thGENRETARD
03-05-2004, 07:42 AM
Don't mess with MAFT if you do not know your base AFR. You got to have a base to make adjustments. Guessing is no good with tuning.
samz28
03-05-2004, 08:00 AM
especially with nitrous, brave man you are. lean her out up top, melt some 8 pistons real quick ;)
slik98z
03-05-2004, 10:42 AM
I've had it dynoed but it was stock. I don't have the paper with me but i was told the a/f was right where it should be. I added a catback and lid as my only other mods other than the nitrous kit, which i don't use very often. Im pretty confident that i will be a little bit rich but nothign to worry about. And wouldn't be ever so slightly rich onlyhelp with the nitrous?
besides if i start fuggin shit up it gives me a reason to tear it apart and start from scratch :)
thanks fellas
Travis
LS1-SSS
03-06-2004, 08:33 PM
Without a diagnostic tool like AutoTap an MAFT won't do you much good. You won't know what to set the MAFT to if you can't monitor base and wot ltrims and O2 readings.
If you have AutoTap then an MAFT will do a reasonable job of letting you make adjustments to generally keep your a/f relatively safe. I used one for a couple of years with my supercharger.
However, professional tuning is best.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
