Rauch
08-30-2011, 12:44 AM
With the passing of Irene, I noticed some more water in my hatch, except in the spare tire well this time. -_-
I'm hoping the weather for tomorrow is going to hold up, even though I planned to install my new head-unit, I may as well put that install on hold.
Upon a quick dis-assembly today, I did notice there's at least 1-2 portions the the hatch seal the is lose. (i.e. pulls off the mounting surface with very little force.) So, as of right now, I'm nearly 100% certain that's the cause for my occasional flooding.
Would it be entirely appropriate to use RTV on the seal to the mating surface, or is there a better product to look into?
But, in the process I also discovered half my tail light grommets were missing or dry rotted. One to two areas had some slight surface rust. So, I'm going to seal the tail lights up with some RTV tomorrow.
While I'm on the ball, I'm going to finally get around to readjusting my driver window due to the occasional drips I get when driving in the rain. Approximately in the middle of the window, so I'm almost definite it's just the adjustment.
Lastly, I got up to the windshield... And to my surprise, I found the seal along the perimeter to pull off rather easily (and GOOEY!). Which, even through my untrained eye, doesn't seem right. I've been looking online for the GM Urethane Adhesive kit.. Can't find a damn thing. It's probably just an overpriced kit or selection of items I can find at Lowe's in the morning.
Anyone have suggestions for the windshield? Would cleaning the existing (apparent non-sealing) goo out and once again using RTV be okay, or should I look into something a little tougher? I never had to do a windshield seal before. I'm just hoping it hasn't leaked to the point my A-Pillars are rusty and floorboard and firewall as well! Than again, I'm not to certain if it's leaking. Some days, the carpet feels damp, but not wet. Than, I start feeling around and start to believe it's just damp due to the weather/humidity.
Regardless, I think I'll spend the 1-2 hours to strip the interior, pull the carpet back, look for any other visible signs of leakage, and seal my potential leaks.
If the weather is appropriate, and I wake up in a good enough mood, I'm going to document and photograph everything, just for fun. I'm sure it'll help someone else down the road.
So, if you have any good sealant recommendations other than good ol' RTV, please let me know! Gotta wake up early to make a Lowe's trip.
