17x11 rub
Old 08-30-2011, 01:42 AM
jblack245's Avatar
Default 17x11 rub
Does anyone else 17x11 rub when you get into a turn? Mine do. In the rear. Its not lowered. Is that normal?
Old 08-30-2011, 01:55 AM
kyoytey1693's Avatar
I'm interested in this too. I'm in the middle of putting my 315's on. I had the factory wheels widened 2" to the back side and I'm running a 1.25" spacer. I've done a little hammer work and grinding and right now I have maybe a half inch of clearance between the inside of the wheel well and the tire.
How much space do you have?
Oh, mines is also stock height and I have a solid BMR panhard bar.
Old 08-30-2011, 02:33 AM
jblack245's Avatar
I didn't hammer or grind nothing. Didn't measure. Just threw them on. They only rub if I get into a turn hard or near air born lol or coming down to hard from a dip
Old 08-30-2011, 09:38 AM
Deviant LS1's Avatar
I'm running a 17x11 with a 50mm offset. I'm lowered on BMR springs, 50/50 shocks and run an adjustable panhard bar. No rubbing issues here.
Check and see if your rearend is square under the car.
Old 08-30-2011, 09:42 AM
johnLs1camaro's Avatar
i had to trim my bumpstops, but thats it. where does it rub?
Old 08-30-2011, 10:09 AM
HibachiZ28's Avatar
I'm putting 315's mounted on 17x11's on my TA shortly. I'm guessing no fender rolling is required?
Old 08-30-2011, 11:33 AM
^no, if you have passengers and hit a bump it may cut up the sidewall a little, but it wont hurt anything.
mines also lowered 2 inches
Old 08-30-2011, 12:06 PM
sscamaroburn02's Avatar
no rubbing here. stock springs and stock suspension in rear. might need panhard bar to center up the rear just a bit
Old 08-30-2011, 10:22 PM
VinR1's Avatar
I have 36mm offset 17x11 ZR1s and 2" springs. I rolled the fenders just to be safe and use a Founders adjustable PHB. there was slight rubbing on the drivers side but some tweaking with the phb and everything is perfect
Old 08-31-2011, 07:19 AM
I was going w/founders suspension soon. How do you like your PHB? Which type are you running?
Old 08-31-2011, 09:22 AM
VinR1's Avatar
I have the single adjustable poly/rod end version - I love it. Very well packaged, super fast shipping and you can't beat their prices. If installed correctly, I can adjust it in just a few minutes with the car on the ground
Old 08-31-2011, 09:58 PM
jblack245's Avatar
i have black zr1s i got off tomzwheels a few years ago. im not sure what or where it rub i havent checked. but when i get in to a hard turn i hear a rub. i have stock springs and the slp blistine shocks. i dont even know if my rear is centered. i dont know much about suspension and the PHB. i got 173k miles on the car tho.
Old 09-02-2011, 10:41 PM
Chaos07's Avatar
i have 17x10.5 and usually if i have a passenger n go over a bump the passenger rear tire will will hit the fender and cut it but its just a flesh wound nothing serious
Old 09-02-2011, 11:01 PM
ZV8
ZV8's Avatar
On my Z28 I had the 17x11" rim with 315/35/17 Nitto 555r and I had to cut the bumpstops off and I autocrossed on shity stock suspension and it didnt rub at all and I had a **** load of body roll!
Old 09-03-2011, 12:34 AM
Mr.z/28's Avatar
Check where it rubs. If BFH is required do it, or a spacer.
Old 09-03-2011, 11:45 AM
ChrisRZ28's Avatar
When I had a poly/poly adj. bar (Spohn) I would still get rubbing (to much deflection from the poly IMO), and it seemed I could never keep that PHB centered. I didn't really care for that adj. nut in the center of the bar either. I then went with a rod/rod adj. bar and haven't had any trouble since. Instead of just buying 'off the rack', I sourced the bar, rod ends and hardware and 'made' my own PHB. There's threads about making your own PHB on Frrax if that's what you want to do. Not that I thought I could make a better bar then what was out there, it was just something I wanted to do.
Old 09-03-2011, 09:29 PM
69TA's Avatar
if you are rubbing the sidewalls
I have a roller tool that I rent out
Old 09-03-2011, 09:44 PM
02ws.sik's Avatar
My c6 z06 18x10.5 with 315/35r18 dont rub stock hieght. No wheel spacers. I beat my inside fender like a **** with a mallet. It fits where the stock ws6 rims did.
http://i1100.photobucket.com/albums/...AwNjMuanBn.jpg
Old 09-04-2011, 08:43 AM
LS1powerd's Avatar
IF it not lowerd. its probably time to put new springs on!!
Old 09-06-2011, 04:37 PM
sstony's Avatar
Remove bumpstops and grind bracket off if you find it rubbing the inside barrel.
Quick Reply: 17x11 rub
