Cam advise please!!!
I know you guys are probably tired of seeing threads like this but In my case is different, speciallly in another country.
I'm a soldier currently stationed in Germany and I have a 2002 manual WS6, my only mods are K&N FIPK
I bought comp cams 7.400 pushrods and Patriots dual springs with locks and seats, planning to get a pulley, lifters and timing chain. I want to buy a cam that is mean in the street and give me all the hp/torque I can get with stock heads and manifolds with a flowmaster muffler, if I can get to the 400s it would be better, I dont want to buy heads or headers, I only drive my car like 2 miles a day to work, Im planning on mailing my pcm cause theres not tuning in here, Ive read about the EPS 224/230 111 lsa and the CheaTR cam, is there any other toughter cam out there for MY SET UP? I want to be able to sweep some BMWs and GTIs up here with just a CAM. PLEASE HELP ME! I would really appreciate it.
With a M6, and a 224/230 on a 111 LSA, gonna be a lil touchy off idle. Also I'd think with a lot of bucking on a 111LSA, if it has the stock 3.42 gear ?
No headers + a Flowmaster, it's not gonna breathe good enough for the cam to have much of an advantage. With headers and a Magnaflow or something that breathes better, you might see 400 !
After you install a cam you should still check the pushrod length to verify the 7.4 will be ok!
If your going to do a mail order, Try Frost on here as I hear his mail tunes are very good.
I helped a friend tune his Vette on the Autostrada in Italy ( A 1 ) That was a blast zooming past the slower Ferrari's !
Do some searching on Thunder Racing 230/224 or 227/224. With stock manifolds & heads the reverse split cam is supposed to work very well. The 230/224 has an awesome idle sound, the 227/224 is toned down quite a bit. Frost will have a good mail-order tune for that setup.
I'm planning to get headers and Y pipe no more than $500 I heard good things about the bbk PN 16940 it's $499.99 Anybody have any comments or suggestions about LT's & Y pipe for that price range??? And maybe a hooker catback or tsp rumbler or flowmaster american thunder???
if you are tight on money but have to mod.... Budget.
Exhaust
Pacesetter painted headers with pacesetter (or TSP) ypipe
cutout- you can buy them cheap on summit for like 35-40$
I would recommend something around 230/234 .600 111 for the cam..
You will also need a new clutch, you will fry your stocker quick with the added power.
You need exhaust with a cam!
Exhaust
Exhaust
Exhaust
Restricted User
Exhaust
Exhaust
Crane Cams 228/232 .600/.600 112 LSA???
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,700-6,200 Intake Duration at 050 inch Lift 228
Exhaust Duration at 050 inch Lift 232
Duration at 050 inch Lift 228 int./232 exh.
Advertised Intake Duration 290
Advertised Exhaust Duration 294 Advertised Duration 290 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.600 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.600 in.
Valve Lift with Factory Rocker Arm Ratio 0.600 int./0.600 exh.
Lobe Separation (degrees) 112
