Convertible Vehicles - Sound Deadener
View Full Version : Sound Deadener
chobes
08-30-2011, 07:17 PM
Has anyone installed any sound deadener into their convertible?
libertyforall1776
08-30-2011, 11:03 PM
No, but if you don't have thick floor mats, like SLPs or the expensive ones like Lloyds, that will help...
NC01TA
08-31-2011, 06:24 AM
What's so loud that you need soundproofing? Just curious if it is the exhaust (is it aftermarket??), engine noise, or even wind noise. Our 'stock' T/A is the quietest of the 3 verts we own.
chobes
08-31-2011, 08:56 AM
I've been thinking that some sound deadener will kill some of the engine and road noise, especially when the top is up. The doors would benefit as well. The exhaust is a bit loud, but that's a good noise to hear.
BobDoLe
08-31-2011, 06:23 PM
a lot of the sound comes through the top. what can you do about that?
NC01TA
09-01-2011, 07:53 AM
If you have the original top with the headliner still intact that is about all you can do as far as noise unless the seals are bad around the edges and doors. Just part of the vert ownership experience. If you have a non-original top then that is probably the problem. I would think your exhaust (if on the loud side) would drown the other things out. Not sure what else to suggest.
chobes
09-02-2011, 04:04 PM
I'm not worried about the sound coming through the top, it's still in great shape.
There's a few rattles in the doors that I haven't been able to eliminate, some sound deadener would take care of those. Same situation on the firewall/floor, looking to eliminate some noise.
Was just looking to see if anyone has installed it in convertible...
libertyforall1776
09-24-2011, 12:42 PM
http://www.stockinteriors.com/AutoCarpet.asp?Itemid=6405&MakeId=5&ModelId=71
Just get the Ultra Plush Cut Pile with the Mass Backing options and there's a much quieter 4th Gen.
chobes
09-28-2011, 09:51 AM
That's a good option, will have to look into it. Thanks for the link.
99'CajunFirehawk157
09-29-2011, 05:34 PM
My cars a 99 and I don't have any door rattles, pull the panels off and go for a ride, should not be anything in there loose, IMHO.
mx505
10-24-2011, 06:49 PM
I did the floor, trunk and doors with Edead from Elemental Designs 2 years ago. It is a noticeable improvement, but I wouldn't expect quiet like a luxury car. Expect several hours of work as well. I would do it again though
