exhaust trouble.
exhaust trouble.
hey i had bought new header bolt to go with my long tube headers and the off road pipe all of it will line up correctly i have the header gasket but not the MAP gasket anyone that has done this swap did you change those gaskets as well if so where can i get a good price i dont wanna spend $120 on nall new gaskets and bolts thats over needed and over priced
Rather than the MAP Sensor, I believe the O.P. is referring to the A.I.R. & EGR System Gaskets that mate these systems to the Exhaust Manifolds.
Every LT installation I've been a part of we installed new Gaskets that were purchased at a Dealership. You'll need one for the EGR for the Passenger Header and two A.I.R. Gaskets (one for each header). They're really not all that expensive and are good insurance to be sure you don't have any exhaust leaks.
Good luck with your install.
