which maker for 3.73?
Internet Mechanic
Although it will probably have more to do with the install then the gears, I tend to see GM Motive or Yukon to make the least amount of noise. My exp says Richmond tends to be much louder. Hope that helps.
** on a side note, I do not know each gear set's particular make up of metals used as some are better for strength but at a sacrifice of road noise and others tend to be quieter but not as loud.
AAM gears are the OEM and they should be quiet like stock. Blue box (stock) Motives in my experience have been very quiet as well. Yellow box (performance) Motives have been good also but tend to whine a tad. Never used Yukon...
