Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
01 corvette z06 built 800hp on boost
Old 08-31-2011, 12:07 PM
indianakid's Avatar
Default 01 corvette z06 built 800hp on boost
Year: 2001
Make: Chevrolet
Model: Corvette
Price: $29900
Mileage: 138
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Silver
Transmission: Automatic
Drivetrain: Rear Wheel Drive
2001 zo6 corvette with auto conversion 138k owned it for 5 years time for somthing new (dont have to sell)
Motor 383 forged super charger ls1 built by golens engine services out of hudson, nh
eagle 4340 forged steel crank
eagle h- beam rod 4340 forged
mahle forged pistn with coating
mahle plasma moly rings gaped for boost
com cams pro magum rollor rockers
clevite h-seriers bearings
com cams lifter 875-16
vale springs com cams
timing set manley double roller
oil deliverly slp performance
head gasket fel pro mls
all hard wear is ARP
heads are 243 fully ported (new casting)
cam specs are comp cam
intake 601 exhuast 601
duration intake 214 exhuast 224
lobe sep 114
Blower setup East coast supercharger
novi 2k kit with about 7k miles on it,, with biggest incooler i could fit
flip drive only a couple monthes old less than 500 miles
has 3.25 head unit pully on blower 8 rib
Innovators West 10% overdrive balancer 8 rib (500 miles)
ford anderson meth kit around 7k miles also
Injector Dynamics 1000cc injector (500 miles)
Turbosmart Blow Off Valve from a&a corvette
auto meter boost gauge + a dual pillar pod + inovate wide band.
susp.
QA1's 12 way adjustable shocks front and rear .
Street rims
OEM z06 rims powder coated black with newer tires
drag pack weld drag lites
are a set of weld drag lites 17's in the front and 16's in the rear they have newer hoosier 28.10.16 slicks and front are m&h's
fuel system
complete fuel system aeromotive rails, aeromotive fuel reg. feed and return lines are -8 braided line , fuel pump 2530 weldon race pump external good for 1200hp ....my set up is the car drives on the stock pump and any rpm over 3k the weldon pump comes on and this is controled by a rpm box switch that uses rpm pills etc.
tuning
HP tuners pro + labtop and carrying case
Transmission
LEVEL VI 4L60E automatic transmission from RPM transmission with a 2800 lockup vig. converter 3 disk. + DTE trans/diff brace its powered coated black
Rear diff
3 rib 3.42 diff hardened shafts
Exhaust
not sure on header brand bought from lingenfelter 5years ago has x pipe and stock TI mufflers very quiet car..
car made 700hp on 10psi was outa fuel.. with fuel system now upgraded and now at 15psi has not been back on the dyno but my guess is 800 to 850 rwhp ..been to track a few times i have numbers for serious buyers...
Car is located in NW indiana about 45 mins from chicago 219-256-4997 call or text with any questions asking 29,900 TRADES welcome what you got. thanks
Attached Thumbnails 01 corvette z06 built 800hp on boost-577.jpg   01 corvette z06 built 800hp on boost-579.jpg   01 corvette z06 built 800hp on boost-594.jpg   01 corvette z06 built 800hp on boost-593.jpg   01 corvette z06 built 800hp on boost-vette-2.jpg
01 corvette z06 built 800hp on boost-580.jpg   01 corvette z06 built 800hp on boost-601.jpg   01 corvette z06 built 800hp on boost-602.jpg   01 corvette z06 built 800hp on boost-599.jpg
Old 09-01-2011, 10:13 AM
indianakid's Avatar
typo------ weldon pump is a 2025 my bad..... bring on those trades
Old 09-02-2011, 06:36 PM
indianakid's Avatar
nobody wants a fast fast z06 that can be driven anywhere raced and drive it home
Old 09-06-2011, 04:47 PM
indianakid's Avatar
price reduced 28k
Old 09-09-2011, 10:58 PM
indianakid's Avatar
Trades welcome
Old 09-16-2011, 06:23 PM
170mphparachute's Avatar
to the top
Old 10-16-2011, 08:12 PM
BOTTLEFEDSS's Avatar
what kind of trades are you looking for?
Old 10-18-2011, 12:06 AM
BLWN1's Avatar
I have a duramax dually and a roller coupe ready for amotor/tranny(LS1) to offer...
Quick Reply: 01 corvette z06 built 800hp on boost
