Want to stop fighting my ABS...any ideas?
Since Ive had my staggered Zr1s 9.5 in the front and 11 in the back, the abs fights me at hard high speed stops. It will stop ok if you realize you have to fight back when the pedal starts pulsating. The first couple of times it happened it scared me to the point where I didnt think I would be able to stop in time, since then when im concious of it I will put a lot more braking pressure and it stops fine. Is there any way to fix or make this better without deleting the abs or getting non staggered wheels? I like having ABS and 11s out back. Any input would be greatly appreciated.
Trunion King
Yeah I get that....I probably should have been more clear. It will hit the abs if Im going lets say 80mph and I step on the brakes hard, not panic hard, but hard even if Im only slowing down a little and it will fight me and it cuts down on braking time. The wheels arent slipping and theres no reason it should kick in at that point. It was fine before I put staggered wheels on it.
I recently installed a set of draglites and slicks in the back with skinnies up front. Had this same issue when coming to a stop at the end of the 1/4mile. Scared the crap outa me to. Slicks are 26x11.5x15.
Would like to find a solution for this as well.
[edit] Well after a quick search it looks as though it is caused by having different diameter tires front to back. The abs sensors need to have all the tires the same diameter for it to work correctly. Aside from deleting this out with tuning i wasn't able to find another solution.[/edit]
Copy & Paste Moderator
Two things:
1. Make sure the front & rear tires are the same diameter
2. Get stickier tires.
Different diameters will trick the ABS.
Hard/Cheap tires don't grip as well.
My tires are bfgoodrich kdws on the front and sumitomos on the rear
Those sizes will have no effect on the ABS I ran them for 3 years and many others have as well. As long as the height difference is >1.5" you are fine and width doesn't have any effect with it either.
I have stock zr1s 275 40 17 on mine and have always disliked my abs. Breaking at high speeds especialy around corners the brakes just seem to let go or "fight back" so then I have to really push on that sob. I hate it. I may delete it someday and I bet I wont miss it.
then you need more aggressive pads bc whatever you're using obviously isn't doing very well. Also you should learn to brake hard without getting into ABS. It keeps you from locking up, but doesn't help you stop any faster. If you brake to the threshold of just before ABS, you will stop faster and not have to worry about it
