TSP Tqr V2 and washington Sniff test
Old 09-01-2011, 02:09 PM
the_reaper's Avatar
Default TSP Tqr V2 and washington Sniff test
SO I am looksing at the TSP tourqer V2 cam, THis will be on a stock LQ4 bottom end with LS3 heads and a LS3 intake. I am starting from scratch so I have not yet purchased an ECM. My question is that Its going into a 93 Jeep YJ and I will have to pass the sniff test. IS it possible with this cam ?
Cam Specs will be
232/234 .595"/.598" I was thinkong about a 113 or 114 CL
Old 09-01-2011, 02:19 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
If your sniffer test is anything like California's, then no it will not pass. You might ask in the Western Regional Forum and see if any of the locals have any feedback.
https://ls1tech.com/forums/western-members-59/
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-01-2011, 02:41 PM
the_reaper's Avatar
Matt thank you, Not sure about Ca sniff test. here are the standards that I have to pass, THis was with a Stroked 4.6 Inline 6 with a whipple and a gen 7 running 26lb injectors
Old 09-01-2011, 02:42 PM
socal's Avatar
my bro has this cam on 116 lsa in his ls3 92 z it passes w cats and a good tune in tx. 2nd this cam is kind of big for a trail truck and i dont think it matches the ls3 heads to well and i think you would be spinning the motor up to high for off roading if thats what youll be doing.
Old 09-01-2011, 02:46 PM
the_reaper's Avatar
THis is going into a 93 YJ jeep with a 4l70E trans and 2800 stall, this jeep will see sand dunes and unexpecting 5.0's thats about it
Old 09-01-2011, 06:03 PM
BLK02WS6's Avatar
That cam is not a good choice for those heads...
Old 09-01-2011, 07:31 PM
the_reaper's Avatar
I am open to suggestions
How about the TSP 228R on a 112 or 114 CL
Old 09-03-2011, 09:51 AM
BLK02WS6's Avatar
Most of the shelf cams out there are for cathedral port heads... I would find a reputable custom grinder and get one specific for the setup you have. Do some research on here for custom grind cams, and find out who knows what they are doing...
Old 09-03-2011, 10:09 AM
the_reaper's Avatar
trying to learn looks like PAT G is the one to goto, not whure how to go about it though
Old 09-04-2011, 08:59 AM
BLK02WS6's Avatar
Send him a PM and he will give you the details.
Old 09-04-2011, 11:38 AM
the_reaper's Avatar
Just did, Thank you
